Those of us that choose to run Open Source Self Hosted applications do so because of privacy, security, and flexibility. Customer service is important for a company to thrive and build a strong reputation. Sadly, customer service is an after thought for many companies. I think a key part of customer service is to find out what customer preferences are.
Creating a survey is a good way to get feedback from your customers and so that is what we cover in this video. Take my survey at:
https://survey.scottibyte.com/index.php/291398?lang=en
You can also access the survey via QR Code.
We will install limesurvey which is a simple Docker application. However, I like to create a LXD container in which to nest my Docker applications for isolation and security reasons. Below, I create a LXD container and bridge it to my main LAN. Note: Bridging is covered in my other videos.
lxc launch ubuntu:22.04 Survey --profile default --profile bridgeprofile -c boot.autostart=true -c security.nesting=true -c limits.memory=4096MB -c limits.cpu.allowance=20%
Sign into the LXD container with the following:
lxc exec Survey bash
Perform updates on the new container.
apt update && apt upgrade
Add a user account, install docker and grant the account sudo and docker privilege.
Move over to the account and create an application folder and move inside it.
mkdir limesurvey
cd limesurvey
Edit a docker-compose file.
Insert the following in the file, adjusting passwords accordingly and changing the exposed port if necessary…
version: '2'
limesurvey:
image: acspri/limesurvey:5.5.1
build: .
LIMESURVEY_DB_PASSWORD: dbPASSwoRD1
LIMESURVEY_ADMIN_USER: scott
LIMESURVEY_ADMIN_PASSWORD: adminPASS
LIMESURVEY_ADMIN_NAME: Scott Thompson
LIMESURVEY_ADMIN_EMAIL: vmsman@scottibyte.com
- ./plugins:/var/www/html/plugins
- ./upload:/var/www/html/upload
- ./config:/var/www/html/application/config
mysql:
image: mariadb:10.5
MYSQL_ROOT_PASSWORD: dbPASSwoRD1
Save the file and then bring the app up:
The steps to create a domain name and add the reverse proxy are covered in the video.
