This tutorial is about moving Proxmox LXC containers to LXD Containers on a LXD server. This will be followed by another tutorial showing how to migrate a Proxmox Virtual Machine to a LXD Virtual machine.
This is accomplished by making an image of the Proxmox LXC container, adding metadata to it, and importing these components into a LXD Image. Then we use the LXD image to create a LXD container.
To initiate this migration, I ssh’ed into the root account on my Proxmox server (your Proxmox server address will differ):
ssh root@172.16.1.165
Move over to the /tmp folder on the Proxmox server:
cd /tmp
List your Proxmox containers:
pct list
Make a note of the LXC container that you want to transfer and issue a command like the following to create a compressed image of the container:
vzdump 100 -compress gzip -dumpdir /tmp
Next we have to create a metadata file to go along with the LXC image file dump:
echo architecture: `pct config 100 | grep arch: | awk '{print $2}' ` > metadata.yaml
echo creation_date: `date +%s` >> metadata.yaml
echo description: 'Imported from Proxmox' >> metadata.yaml
The metadata file must be placed into a compressed TAR file:
tar -czvf metadata.tar.gz metadata.yaml
You can delete the metadata.yaml file now:
rm metadata.yaml
We now want to copy the dump file and the metadata file to your LXD server. I used secure copy to do this (I created a “migrate” folder on the LXD server just to keep track of the files more easily):
scp vzdump-lxc-100-2023_07_06-13_47_39.tar.gz metadata.tar.gz scott@172.16.1.225:/home/scott/Desktop/migrate
Next, I logged into my LXD server (again, your address will differ):
ssh 172.16.1.225
I changed to the folder where I placed the two files:
cd Desktop/migrate
Next, import the two files to create a LXD image (the alias name is the name of the image):
lxc image import --alias=fromproxmox metadata.tar.gz vzdump-lxc-100-2023_07_06-13_47_39.tar.gz
List your images on your LXD server:
lxc image list
Create a new LXD container from the image that we just created (Test is the name of my container):
lxc launch fromproxmox Test -c boot.autostart=true
From my “LXD Step by Step” tutorial, I assigned the profile we created in that video to bridge the LXD container to an address on your LAN:
lxc profile assign Test default,bridgeprofile
After a minute or two, you can list your LXD containers and see the newly updated address on your LAN of the newly created container:
At this point, you no longer need the image we created unless you want to create other containers based on the image. So you can delete it if you like:
lxc image delete fromproxmox
Deleting the image does not affect the LXD container we just created.
Now you have a fully migrated LXD container that came from a Proxmox LXC container.
