Incus Servers in Home Assistant
ScottiBYTE Incus is a Home Assistant Integration that I vibe-coded in ChatGPT which I hope you will find useful for basic maintenance of your incus containers.
If you are a Home Assistant user then I think this makes Incus container usage more accessible.
If you are not yet running Home Assistant, then watch my Home Assistant OS in Incus 101 video which I created in June of 2025.
ScottiBYTE Incus is a Home Assistant Community Store (HACS) integration that creates an Incus container management dashboard in your Home Assistant side panel.
You will need to have HACS installed in order to install the ScottiBYTE Incus Home Assistant Integration. My 101 video above includes installing HACS.
Go to HACS in your side bar menu.
Go to the 3-dot menu in the upper right of HACS and click on it and choose the “Custom repositories” option.
In the “Repository” Field, enter:
https://github.com/ScottiBYTE/ha-scottibyte-incus
which is the URL for my GitHub project for the code. Specify the type as an “Integration” and then click “Add”.
If it returns to the “Custom repositories” popup screen, just X out of it.
In the filter field at the top of the screen, start typing ScottiBYTE and it should find the repository.
Click the Integration and then click the blue download button.
Click download again at the following screen.
When the download completes, note the yellow 1 next to settings.
Click settings and you will be prompted to restart Home Assistant.
Once you submit the restart option Home Assistant will restart to load the new Integration.
After Home Assistant is back up, go to Settings – Devices and Services – Add Integration. Start typing “ScottiBYTE” and you will see the new integration.
Click on ScottiBYTE Incus and select the Automatic Setup option.
On the automatic setup screen you will be adding the name, address, username and password for your Incus server.
Once you have completed those steps, press Submit and you will get a courtesy prompt regarding a new ssh signature having been added. You can accept that with the submit button.
The next screen lists all your containers, but you also have the option to specify the area or room in which your incus server is located. Clicking skip and finish is fine if you don’t care about the room.
You can now click on “Incus” in the Home Assistant sidebar.
Use the Add/Manage servers buttons at the top of the screen to add additonal Incus servers to the dashboard and you can remove them as well. Follow the video to learn about the other options.
UPDATE: Since the video, I released V1.2.0 which adds Server Stats to the server cards as well as a “refresh” setting at the top.
The CPU load, Memory load and detailed file systems utilization are now on the main server cards as shown above. Adding a new server will automatically include these.
Adding server stats to an existing server is achieved by going into “Manage servers” and clicking on the 3-dot menu and selecting “reconfigure”.
Choose the set up or disable whole server metrics.
Finally, authenticate.
Let me know in the ScottiBYTE RocketChat if you have any questions or just to say hi. I hope you find this useful.
