In the past, I have covered virtualization for VMs, LXD containers and Docker. This presentation focuses on how to present Docker containers on the MAIN LAN and also on VLANs. By default, Docker runs all containers on the host IP address and exposes unique port numbers.
Here are commands used in the presentation. Addresses used are for example only. Yours will differ.
For example:
docker run -d -p 8080:8080 rofl256/whiteboard
If you have several containers on your Docker host that want to run on port 8080, you need to expose different ports to avoid conflicts.
Helpful commands:
ip route show - learn the names of your host interface
docker ps - List all running docker containers
docker network ls - List Docker networks
docker image ls - List Docker images
Create Interactive container on Docker LAN
docker run -it --name=test ubuntu bash
apt install iputils-ping
apt install net-tools
Create Docker Interactive container on Untagged LAN example
In this example, 172.16.0.0/16 is the MAIN LAN address range and 172.16.0.1 is the gateway address on the router. The 172.16.1.200 address is an example address of a container on the MAIN LAN.
docker network create -d macvlan --subnet=172.16.0.0/16 --gateway=172.16.0.1 -o parent=enp4s0 exposed
docker network ls
docker run -it --name=test --net=exposed --ip=172.16.1.200 ubuntu bash
ping 172.16.1.225
Create Docker Interactive container on VLAN example
In this example, the assumption is that VLAN 80 exists on the current managed network. The address 192.168.80.111 is chosen as the address of the new VLAN80 network device on the Docker host.
sudo ip link add link enp4s0 name VLAN80 type vlan id 80
sudo ip addr add 192.168.80.111/24 dev VLAN80
sudo ip link set VLAN80 up
Next, a Docker network is created in the VLAN address range of 192.168.80.0/24 and the parent device is the host VLAN80 device.
docker network create -d macvlan --subnet=192.168.80.0/24 --gateway=192.168.80.1 -o parent=VLAN80 vlan80
Finally, the container is run on the vlan80 network. Note that I made the host device name in uppercase and the docker network name is in lowercase just to point out the difference. You can use two different names if you like.
docker run -it --name=test --net=vlan80 --ip=192.168.80.112 ubuntu bash
To delete the docker network once no containers are using it: docker network rm vlan80
To delete the host device:
Stop containers using it.
sudo ip link set VLAN80 down
sudo ip link delete VLAN80
Stop all running containers (DANGER): docker stop $(docker ps -aq)
Remove all containers (DANGER): docker rm $(docker ps -aq)
Delete all images from your Docker system (DANGER): docker rmi $(docker images -q)
