To build an Ubuntu Desktop in Docker, we will be creating our own docker image with the “docker build” command.
To do this, edit a file named dockerfile:
nano dockerfile
In the video, we used the following content. Make changes for your specific needs:
FROM ubuntu:latest
RUN apt update && DEBIAN_FRONTEND=noninteractive apt install -y lubuntu-desktop
RUN rm /run/reboot-required*
RUN useradd -m scott -p $(openssl passwd testing)
RUN usermod -aG sudo scott
RUN apt install -y xrdp
RUN adduser xrdp ssl-cert
RUN sed -i '3 a echo "\
export GNOME_SHELL_SESSION_MODE=lubuntu\\n\
export XDG_SESSION_TYPE=x11\\n\
export XDG_CURRENT_DESKTOP=LXQt\\n\
export XDG_CONFIG_DIRS=/etc/xdg/xdg-Lubuntu:/etc/xdg\\n\
" > ~/.xsessionrc' /etc/xrdp/startwm.sh
EXPOSE 3389
CMD service xrdp start ; bash
Build your image and name it. Mine is named “desktop”:
docker build -t desktop .
List your docker images:
Run your desktop using the address of the docker host:
docker run -it -d --name=mydesktop -p 3389:3389 desktop
To create another container using the same image, but offering this container on the LAN, we create a docker network as in the previous video:
docker network create -d macvlan --subnet=172.16.0.0/16 --gateway=172.16.0.1 -o parent=enp4s0 exposed
Start the container on your MAIN LAN using the “exposed” network:
docker run -it -d --name=lan-desktop --net=exposed --ip=172.16.1.200 desktop
Remember to change the parent Ethernet device to match yours and the addresses to match your network in the examples above. Review my video entitled, “Docker Networking”
